List of surfaces outputs null, but individual surfaces valid
Hello! I’m writing some code to draw contours from a point cloud and then create surfaces from those contours. It is so close to working, but I’ve run into this hiccup that I can’t seem to get past. The last few lines of the code output all the contours and then should output the rs.AddPlanarSrf() of those contours. When I connect the surface output to a Surface node, it receives a list of null values. I thought at first that this was because I was not properly making the surfaces, but if I output any individual value of the list, it successfully returns the surface. Can any of you help me figure out why that is?
Code_Snippet
Code_Snippet_Individual_Instance
Successful_Individual_Surface
Mountain_Troubleshooting.gh (455.3 KB)
@Charles_Biggs
Very interesting approach.!
Anyway, if you connect your Contour curves output to a surface container you will get what you are looking for, instead of dealing with data trees inside python.
Ragards :slight_smile:
That worked! Thank you so much!
