I have put together a list of numbers coming out of the random command and I want to take those numbers and make them into 2 dimensional points. I believe I would use the unflatten tree command, but I cannot find how to create the syntax anywhere. If that is the best tool for this, how do I get the list into an x,y list. If not what would be the command to use and how do I use it.
Thank you.
@VioletRain, just plug it into a VectorXYZ component
c.
That didnt work for me.
Random_Points.gh (3.8 KB)
Actually if I use a panel it seems to be working, I thought Param Viewer did the same thing, sorry.
@VioletRain, to get different values for x and y, try to provide two random components using different seed values as attached below.
Random_Points.gh (8.4 KB)
btw. there is a Populate2D component which does basically the same.
c.
You can also generate twice the amount of random values and then use a Numbers To Points component with an XY mask.
