Is there a way to make the default mode for the List Item node’s W (Wrap list) set to False rather than True?
I almost never simply shift the entire list, but want some item shifted out of existence, so I always have to make the extra clicks to change the boolean toggle. Can I set this by default somehow?
Thanks,
Matt
attach a false input to it, wrap it into a cluster, call it something like “List Item No Wrap”
Well that makes complete sense. Much appreciated.
I forgot, after you make the cluster then select it and go to File>Create User Object, So you can have it saved in your grasshopper tabs to keep reusing. If you didn’t know already.
