Hi
I noticed that if there are more than 50 item looped into the list item command, the branch name is autimatically changed.
However I would like the same branch name.
Doe any one has an idea why this is ánd how to work around? thanks
not sure if i understand correctly but have you tried simplifying the tree?
Not sure why this would be happening, or if it is related to list length. However, to avoid it, I’d reccomend using “Principal” - Right click on the node input whose tree structure you want to keep, it’s the one with the black/yellow arrow.
