Linking error with CRhinoApp::OnEscapeKeyDown(void)
I’m trying to use simple function OnEscapeKeyDown() in my C++ plugin for Rhino6 and I’m getting unresolved external symbol error on it. Here’s the line of code which produces it:
if (RhinoApp().OnEscapeKeyDown()) return nothing;
The line is within myClass::RunCommand(…){…} and myClass is derived from CRhinoScriptCommand.
At the same time, I see that another function works fine (no compiler/linker errors):
RhinoApp().RunScript(context.m_doc.RuntimeSerialNumber(),…)
Both functions are defined in rhinoSdkApp.h in CRhinoApp class and both are public.
I’m using Visual Studio toolset v141 and Rhino C++ SDK v.6.23.20055.13111
Can anyone give me advice on this? Is there some dll missing in this SDK as some other functions also produce linking errors?
Thanks in advance!
  • Andrey
Hi @pyati,
You might have a look at this:
If this isn’t what you want, please post some source code that we can run here - thanks.
– Dale
Dale, thanks for quick reply!
These solutions work for me (I was aware of one of them). I was just looking for some simple higher level function to check for Esc. Just was wondering why I’m getting the errors.
  • Andrey
Hi @pyati,
CRhinoApp::OnEscapeKeyDown is not an exported SDK function. Thus, it cannot be called from outside of core Rhino.
Hope this helps.
– Dale
I see, that explains it.
Maybe it would be good to put a comment for such functions, as they are still accessible from the class.
Thanks!
Ps.: I have another question about CRhinoApp::RunScript and CRhinoApp::ExecuteCommand but I’ll create a separate entry for it.
Exported functions are decorated with a RHINO_SDK_FUNCTION macro. Classes with RHINO_SDK_CLASS.
– Dale
Dale,
You are right, I looked at it and completely missed that there is macro before the functions, now it is obvious (checked the macro). Thanks for clarifying!
  • Andrey
