I have linked several FBX files in my Rhino file. Every time I open it, I am now asked if I want to adjust the scaling.
I work in mm, the fbx file is set in cm.
Can the linked files be scaled by default so that I do not have to confirm the message every time I open them?
Can you explain more about the exact set up you’ve done and also what version of Rhino you are using? From the tags I think you are using Rhino 5 and block instances but I want to make sure I understand how you’ve set up a link exactly. If you can post a sample FBX file that can be used to show the issue that will help too.
