There might be a work-around. Maybe copying an existing linetype… but it’s proving to be a pain.
Edit: One thing that seems to work is to set each one to whichever setting you want then click “okay”… this means you need to close the dialog for each and every linetype… but at least you’ll get them set.
Also if I’m going to bug you about Dialogs, it would be of a MASSIVE benefit if we could SHIFT + Left-Click and check/uncheck multiple Hatches at once in the Hatch dialog. Having to click one check box at a time is killing me. This basically happens when I want to import hatches from a DWG file (it imports everything of course… as it should).
Hi @keithscadservices there are several improvements to linetypes in the upcoming sr6 that should address what you’re seeing.
As for hatch importing. I can tune that up. The +/- selector at the top of the import grid may offer some left click relief for you until I get it working. RH-80699
