Is there any way we can get Linetype properties to work on Leader objects?
-d
-d
You can explode the Leader, select the polyline and change it to your desired linetype. But the arrow will explode to a closed curve. To make it appear as other arrows, you can use Hatch>Solid. Then Group all the items. But, this is more of a slightly time-consuming workaround, if it helps.
