LineType Niggle
Can’t pick a midpoint of a dotted line (unless you’re lucky enough to have a dot at the midpoint of the line)
In fact, seems you can’t pick a dotted line anywhere except on a dot…
Dotted lines seem a bit spesh… is this intentional!? Should we be told? Other line-types seem ok…
:smiley:
The idea is only visible things can be selected. It’s a bit awkward for a dotted line. but it’s worth the trade off.
It’s like the Center osnap. There is no object at the center, so you put your cursor over the object that has a center to find it.
But if I want dots, I’ll make em… :smiley: If it’s a line, you should be able to snap to it. Esp as dotted/dashed lines are often used as construction guides…
(and this is new behaviour in 7 which slipped in unannounced… :slight_smile:
