Lines show only when printdisplay is turned on
They are not selectable and disappear when print display is turned off….?
I should say some lines only show when printdisplay is turned on.
This is Rhino 7
The lines are there but seem to be greyed out which is not the color of the layer they are on.
Hi bwheeler,
Please run the SystemInfo command in rhino and post the results. A small file showing the issue might be helpful in this case as well. Thanks
They could be locked, try the Unlock command.
Thank You….I have no idea how they got locked but that fixed the issue. Never used that command, at least not on propose.
