Hello all,
I have a closed, bottle-like surface with varying diameter.
I generate points on the surface and create lines from those points.
But the line following surface normal’s direction,
test_1.gh (20.6 KB)
(The current document contains 49 objects, and does not depend on any plug-ins.)
and i’m trying to get those white lines,
{ i used a surface offset then i’m getting white lines
but some complex surfaces has offset problem}
i want to ask “ Is there any better way to create those lines “
or any topic which could help me to do this.
