Linear dimension properties for small measurements
For the linear dimension showed in the 1st image,I made a seperate annotation style and customized it. Is there any way that only the number 1 (cm), goes a bit more up than the rest of the numbers like in the 2nd image? Because the way it is right now makes the number 1 not visible. Please feel free to recommend other solutions as well, if this cannot be done with rhino’s settings :slight_smile:
Hi Kaltra -
I’ve seen a few of these lately, and, to me, it just doesn’t make sense. I’m a machine engineer, so it’s very well possible I need to be educated on matters related to architecture.
Is there an ISO standard that governs the placement of those dimensions?
To me, if they don’t fit, they don’t fit. Move them to a separate line.
The other answer is that you can manually turn on the points for the dimension and then move that value to be higher up.
@wim What about the fact that the number is located ‘inside’ the dimension (left to the line), and not on the exterior side? This always bugs me.
Hi Toni -
I’m afraid I need hand-holding here. Can you post a picture that clearly shows what’s happening?
@wim
There are posts about this issue, and I think I have also made some.
This is a continuous annoyance that the dimension text is positioned wrong. I strongly believe and have been taught that the value should be located on outside of the dim lines.
So dim lines with the same offset should fit exactly alike regardless on which side of the object they are located. This is a headache especially with auto-dimensiond parts, as you have to assign extra space if the value decides to flip interior side.
From your side, I see this as a simple fix. Allow user to select the position as “outside”.
Ah, that one, thanks.
Added this thread to good-old RH-53011 Dimension Text: Vertical control of dimension text.
Six years in the making. Should @dale be poked a little on this matter?
Hey Wim thank you for your response. It’s not as much about it being an ISO standard than it is about readability. Of course you could do this manually, but it’s really inefficient when you think about how many drawings and dimension lines you have to deal with in only one single project.
I was hoping rhino had some sort of setting that doesn’t require going back to each single small dimension and moving them up one by one. The ideal end result would be the 2nd image.
