Why is the file with pre-defined line widths so hard to find?
Can you , please, bring it to the Options menu?
Hi Piotr - is the goal to change what shows up in the Properties list for print width on the fly, per file? Or do you still want it set globally, or?
I’d rather see it ‘per file’ as I work on a whole range of projects which needs customized line widths, often more than currently available 2.0.
What do you think is the best?
