Line types with layouts
I really don’t understand: I am using a line with line type “border” and give it a scale of 20. When I print the viewport on a A3 printer, no problem, the line is printed as on the screen. But when printing a page layout (A3) with the same scale than on my screen (where the lines is correctly represented with the hyphens) the same line becomes a kind of continuous line in the print. Why? Where is the parameter for that? Can somebody explain clearly the scaling function.
Hi Andreas -
Without a 3dm file, it’s hard to be sure, but it sounds like you’ll want to check the “Use model units” option under Print and Display at the bottom of the settings for the linetype.
