I have this issue where I want the contour lines in my drawing to all be dashed and at 0.25 width. However upon setting these up, when I create a PDF via print the resulting drawing has some of the lines as dashed but others aren’t.
I have checked everything I can think off, I have attached the file if anyone could help me out!
Ahh I think it was because not all of the lines were joined, this is such a headache because it wont let me select all and join them because some of them are ‘unable to join curve’ is there a quick way to fix this without going through every single line and fixing it?
In DocumentProperties > Units page you can change the absolute tolerance if you want to force curves to join. It’s kind of a brutal approach - just make sure to change it back to whatever you were modeling with.
