Line to Plane Question
Feeling stupid because i can’t figure this “plane” one out simply as it should be
I’ve check other subjects in the forum but can’t figure this out…
I know the Line plane module. It’s (perpendicular) to what i want?
I want to fit plexi panels inside some tube frames at the “right angles”, i need to hold these panels using these sleeves that need to be cut at the right angles. So im creating a mount for the panels and need to cut the “holders” on the tubes on the plane (perpendicular?) to the tube in the right plane/rotation…
The plane here is not right IF i moved any triangle points with a different Y. Yes, it’s 3D now and the xy plane doesn’t work anymore. I can’t figure out how to make the plane from the triangle vector to the 3D plane of the triangle/tubes - i dont know how to explain this…
But if all points have y=0 it works “for the bottom tube”. XY plane…
How do i create this kind on plane on each line/tube to extract the “inside” half extracted tubes parts right (like the green part hilited) and find the right angles to work with if angles of the triangle change?
Plane question.gh (35.7 KB)
I have the same problem to extrude the green plexi glass in the right “direction”…
Im not super good in planes… Algebra vectors I do understand but can’t get this around my head…
Can any of you help please? Thanks in advance!
I kind of got the plexi extrustion vectors…
dear Xavier,
See my suggestion on how to solve this. You might use parts of it like:
I saved it as a Rhino 8 gh file… Now it doesn’t work…
could it be you need to do an update? I am on latest 8 version.
The “pipe” component in my .gh file does nog work in your Rhino.
Let me update a version without “pipes”
Plane question EW2.gh (22.7 KB)
did the update check but seems up to date…
oops, ok, not i see the issue, Rhino 7 is opening… my bad
Yes that works! I’ll try to modularize it tomorrow, thanks very much!
Is grasshopper harder than golf mental sport wise? I wonder :slight_smile:
thank you. Select it as solution.
PS: For getting more/faster answers on the forum, remove plugins before upload. Not everybody has or wants the plugins you have.
regards, Eef
Thanks Eef!
