Hi
V5
I need to draw a line tan from circle and heading due east on ortho view top, but despite ortho being highlighted, it wont constrain to left right movement.
What is happening ?
Steve
Hi
V5
What is happening ?
Steve
I guess this is the way it is supposed to behave, as ortho might interfere with the “tagent from line” line commands.
What you want to do is easy to obtain drawing a simple line from the circle using “quad” snap and “ortho”.
cheers, Norbert
Mmmm… I thought Quads occured at 12 3 6 and 9 oclock on a circle, and couldnt be found outside of those locations. This circle being drawn perp from line of angle 39 deg.
Now an experiment, draw a circle, rotate it about its centre by say 5 degrees, quad is still at top, so quad is an ortho 12 3 6 and 9 oclock position on a circle, as opposed to related to its construction. I learn something every day
Steve
Quad is normally in relation to the active CPlane. --Mitch
But if you are not wanting to draw the line in exact ORTHOGONAL direction, why do you thing ORTHO would help?
Norbert
Thank god it is!
Norbert
Hi.
eh ?
I was wanting to draw in exact ortho.
With me thinking ortho was a fixed 4 point location on a circle and not always related to ortho, with my circle having been rotated a bit, I didnt consider ortho, now I will,
Whatever rotation is given to a circle, ortho will always be at 12 3 6 and 9 oclock, I understand. (now).
.and thank god it is.
Steve
