Line point vanishes totally when zoomed Rhino V8
V8
select my 6mm thickness line, select control points on,
zoom in to select it better and its gone, drag selection box its still gone.
Has no one spotted this bug before ?
Thought I would use V8.
an hour tackling issues, so …
going back to V5 !
Line 6mm point vanishes upon zoom.3dm (14.5 MB)
Steve
Hi Steve,
Strictly speaking, it hasn’t “gone” - it just doesn’t have any visibility unless you turn on the gumball:
However even with the gumball off, if you check the command line after drag selecting over its location you will see that the control point was added to the selection.
I guess this lack of visibility could easily be missed if fat lines are used by few people. I’ve added a “bug” tag to the thread title.
Regards
Jeremy
I need to see the point selected, rather than have faith that its selected,
when it was visible then it vanished, makes one believe its gone, when drag highlighting the end and satill nothing shows visually, my brain says its gone for sure.
This is not CAD .
In V5 its always visible, I cant work this way if V8 does that.
We should be able to use line thicknesses and see points, as we can in V5.
So I am exiting V8, VERY DISAPPOINTED . Need basics to be there, to work, to give confidence.
That this doesnt give positive feedback visually is JUST WRONG.
@dale
@ boffins in McNeel
Need them visible, so back to V5 I go.
I think that goes without saying for CAD users.
If I am selecting points to run a circle through them, gumball doesnt help, unless one can have many gumballs at one.
I dont use Gumball anyway (yes shock horror ) just sometimes.
I try to use V8 and fall at first hurdle. I HAVE TO SEE THESE VISUALLY ALWAYS.
:rage:
Steve
If i understand correctly, try using the PointsOn command on your line.
I see it; this looks to be specific to when print display is turned on.
Hi Japhy,
Thats what I had done, select line, click the PointsOn tool, command line says PointsOn.
zoom in and the point has vanished, drag select and nothing gets selected, nothing goes yellow showing its selected. Line weight thicker and printPreview on so as to differentiate that line.
Repeat this in V5 and at any zoom its always visible and goes yellow when drag selection box around it.
So back to V5 I go so as to be able to work with this.
Had no one come across this before ?
I hope the YouTrack reporting sees a fix soon. what the heck is a ‘Grip’ ?
I know them as control points.
Steve
Try the _ClearDrawOrder command.
@stevebaer
This is also seen in WIP V9.
I think this is a bug related to DrawOrder.
Thanks, I’ve added that information to the YT.
RH-95084 is fixed in Rhino 8 Service Release 33
