Hi everyone!
I am trying to create lines between two points however can’t seem to make it happen (i was able to create the ramps for all the lines except for the smallest circle/ellipse with the next closes circle). These lines will perform later as ramps, and they should be connected from one point to the other. However this should happen (like in the picture) alternatively meaning points from the inner circle should connect to two points from the next circle. Any ideas?
thank you!
I would like to connect point 6 (ellipse) with 9 and 10 (circle), and so on.
