Limitation of Wirecut command
My model included a kicker (blue color) and a solid wall (light grey color).
I selected the layer “slab rebar hole”, it indicated 261 curve selection.
Then I use these curves to wirecut the kicker and solid wall to create holes but it didn’t work.
If the number of object was too large or my Rhino trial version could not perform it?
Thanks
Wire cut.3dm (968.9 KB)
You have a set of duplicate objects (68) on the layer ‘Slab rebar hole’. This is causing it to fail. Use SelDup and Delete, then try Wirecut again. You have a few other dup objects on the other layers too.
