Like Rhino8
I like the “block definitions” panel
with the new command/button
add objects to an existing block
I hope to see a new button soon
to remove objects from an existing block
If I can advise it would be a great thing:
  1. also display the base point in the panel
  2. with scroll buttons selecting instance in
    panel, you also select the objects of the block
edit: when adding/removing objects, with a flag in panel, choose whether to delete object(s).
