Like AlongCrv, but different
this a strange task.
It can be done manually with no problems, but shall be automatic.
The goal is to get evenly spaced points on a contour.
_ArrayCrv is the wrong tool, it produces even distance along the curve.
I need the same distance between the points.
Ideas how to manage it?
Thanks,
-C-H-A-R-L-E-S-
You could do it using grasshopper with a couple of clicks - have it even interactive with distance or points amount and circle diameter etc…
EDIT - hmm or maybe not - what I now see is taht your distance is linear regardless of the curvature… This would need some fiddling with…
Regards,
Mac
Yes, true unfortunately.
Rough idea:
Get the start point of the curve (= last good point)
Make a circle radius = desired distance, center = last good point
Get intersection point from circle/curve
Test, if the intersection is on the curve (in most cases this will be 2 points)
Add the int point to a collection, only if the point was not already there
If success, make the int point the last good point
Start over until no point could be added to the point collection
I still believe there must be an easier way…
-C-H-A-R-L-E-S-
use pythonscript:
divideByLength.py (437 Bytes)
Get radius
radius = rs.GGetReal(“type in radius”)
Make sure its positive
radius = abs(radius)
Get geometrical object
obj = rs.GetObject(“Select a curve to divide”)
if obj is curve
if rs.IsCurve(obj):
# divide by length, geet points
pts = rs.DivideCurveLength(obj,radius,False,True)
# create circles out of pts
for pt in pts:
rs.AddCircle(pt,radius)
TomTom,
this doesn’t result in equal distances between the points…
I mean the length of a line point to point.
-C-H-A-R-L-E-S-
I found this script
https://wiki.mcneel.com/developer/scriptsamples/divideequidistance
Wow, that’s exactly as wanted!
And from what I see similar to my fantasy logic…
Thank you,
-C-H-A-R-L-E-S-
oh, okay my fault
now its even more simple :
divideEq.py (382 Bytes)
rs.DivideCurveEquidistant(obj,radius,True,False)
T-O-M-T-O-M :slight_smile:
Doesn’t Rhino have a command for this?
Is there something I am not getting?
«Randy
Hi Randy - that divides by arc-length along the curve, Charles was looking for even linear distance.
@pascal I see, just rereading this on my dinner break. That is more difficult.
Yeah - RhinoScript has a method just for that - DivideCurveEquidistant().
Thanks TomTom,
I think simpler is not possible…
…great
CharlesCharles :slight_smile:
