In this post @DavidRutten shows how to control lights via C# in GH.
The script works great, but I would need an additional input which is light intensity. (so far the scripts inputs are location and colour only)
Would be great if someone skilled in C# can help me out…
Should just be adding this line.
light.Intensity = Intensity;
lightanimation.gh (8.4 KB)
Works great, thank you Michael!
There is still a strange problem:
When I copy past the script into another or the same file it turns red and says:
- Error (CS0246): Der Typ- oder Namespacename ‘Color’ konnte nicht gefunden werden. (Fehlt eine Using-Direktive oder ein Assemblyverweis?) (line 54)
Meaning that the type or namespace for ‘Color’ couldn’t be found.
Even if I copy the other components into that file it works only until I reload the file.
This happen also to @DavidRutten original scripting component.
Any ideas?
It’s a bug in the current Grasshopper release.
You’ll have to open up the script and in the white region near line 12 type either:
Imports System.Drawing
if it’s a VB component or:
using System.Drawing;
if it’s a C# component.
