Lighten up a selection of solid
would like tot create this grid in 3d for realistic render but there is so much solid and rhino cannot support.
is it possible to create a proxy from a selection of solid (pipes) in rhino ? how ?
You can create your own transparency map.
The video linked in this post explanes how to viewcapturetofile:
Uploading files seems to be impossible right now
Basically you need to create a black and white transparency map with a repeating, seamless pattern which you can apply in the transparency channel of the material.
light_transparency_map.3dm (188.2 KB)
Aside from the good idea of using a texture map instead of actual geometry, you could probably also ExtractRenderMesh > Hide or Delete the solids assuming they are polysrfs > Join the individual meshes into one disjoint mesh with the Join command.
