License removal
I m a new user of Rhino. I recently installed the software, it was working properly apart from package manager issue. But now it is showing this kind of problem after reinstalling the software. Kindly help
Is this an evaluation version or a paid license?
its a crack version…i worked really fine till this happens…others using same doesn’t face such issues
Well, you won’t get any support here for using cracked versions… :roll_eyes:
i m a student…where can i get official one with student license
You can either order one from a reseller in your local region or directly from McNeel. You will find your local/regional resellers listed on the “Buy” page of https://www.rhino3d.com/ Further down on the same page, you will see a “Buy Online” link to buy from McNeel. In both cases you will need to provide proof of your student status. Rhino - Educational Proof of Status
thank u
I was using rhino 7 from last couple of weeks and it was working quite good. The only problem was related to package manager, thus for fixing this issue i restored the firewall settings. Now everytime i open the rhino, it shows license removed. Kindly help me through this.
Merge the topics maybe?
Done.
More merging coming up…
anybody found the solution of this problem regarding Package Manager failure?
Maybe you need a legitimate copy of Rhino for it to work?
Thank You for reply, but this problem already exist there
It is a legitimate
Please run the Rhino SystemInfo command and copy-paste the result here.
can you explain me a pathway to systemInfo. pls
It’s not a pathway. Literally go to the command line at the top and type ‘SystemInfo’.
It will produce a lot of text that you need to copy and paste into the forum here.
Rhino 7 SR33 2023-9-5 (Rhino 7, 7.33.23248.13001, Git hash:master @ 332dda7497b18e9e6f82f118da5cba0c448151a9)
License type: Corporate, build 2023-09-05
License details: Stand-Alone
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 15Gb)
Computer platform: LAPTOP - Plugged in [91% battery remaining]
Primary display and OpenGL: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 10-25-2022 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 22.20.44.221025
> Integrated accelerated graphics device with 5 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 10-25-2022
Driver Version: 31.0.12044.3
Z-Buffer depth: 24 bits
Total Video Memory: 8102 MB
C:\Users\basit\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23187.1334
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.33.23248.13001
No, it is not…
Oh…but sir this problem is already there
many other users are reporting the same problem here as i can see many posts of the individuals with legit software
