I’m getting the error “Cannot communicate with the license manager. Flamingo will not run”. How can I fix this so I can use Flamingo NXT?
I did reload the software after a clean uninstall. No luck. When I check for updates, I get the same error.
The “technical support” topic is page will fix it.
http://wiki.mcneel.com/zoo/rhinolm5
So will installing Rhino 5 SR8…
Worked perfectly. Thank you!
