Oops! The server encountered an issue with your model:
I have just reuploaded a previously working definition which worked with Opennest 1.2, however, I now receive a message as below that the plugin is not supported.
Please advise.
Your model uses one or several plugins that are not currently supported on ShapeDiver:
Library OpenNest OpenNest 1.2 by Petras Vestartas may not be used yet.
You can check the full list of Grasshopper plugins supported on ShapeDiver here:
The definition was originally 1.2 and returned the error messages.
I have tried version 1.3.3 and also then reverted back to 1.2.
Same error message, just different version number…Library OpenNest OpenNest 1.2 by Petras Vestartas may not be used yet.
We have a developer working on the implementation and have your paid hosting, but now can not use the Shapediver platform and our developer can not work on the project.
Surely there is a quick work around, we have never previously had problems with Opennest 1.2 and Shapediver.
That’s great, I was concerned that it may be the end of the month before a fix.
Are you rolling out support for the latest version later in the month?
Can you tell me exactly where to download this version 1.2.00 that it is asking for? I downloaded Opennest 1.2 from food4rhino, but ShapeDiver importer still returns an error. Thanks!
