Levels And Cut Planes Not Working As Expected
Thank you gentlemen, I had the same problem. Removed the 2nd building and the problem is solved.
Hi, Enrick. Removing another building works great, but if i need to make two buildings with different levels heights in one file, how do i do it?
Hi @Chizh you can click on the building icon in the Level Manager to create a new building:
In VisualARQ 3 it is possible to have different buildings with their own elevation and boundary. Take a look at this video for more details: https://youtu.be/tiFcS3u7-fI?si=RkCPl1ia2G7kVPQZ
Thanks for the video. But in general, that’s how I created levels and buildings, and there was a problem with the cut planes - they didn’t work correctly - at the wrong levels and at the wrong height. It was the removal of the second building that helped fix everything, but only for one building. But I want two or three. Screenshot for example:
@enric
Hi @Chizh I recommend you to assign a boundary to each one of your buildings. Otherwise, when you activate a cut plane, it will affect the entire model, while if you do it on a level in a building with a boundary, it will only clip the levels in that building.
Thanks a lot! It helps!
