Hi everyone!
I read some topics about your advices on video cards and computers to buy.
However I still have some doubts.
Can this workstation with these features work well with Rhino software?
Even if the RTX A2000 is the Ada generation GPU, you absolutely should not be paying €2500 for this build.
That is probably €400 [CPU] + €600[GPU] + €100 [RAM], and €80 [storage]. The rest is likely a cheap case, and a generic cooling solution and PSU.
Note, I am coming at this from what the parts are worth, not what a typical business pays. However, if you have the choice and flexibility, there is no reason to pay anything over €1500.
You’re paying an awfully huge premium for the brand name and the fact that it’s “small,” and the video card it NOT impressive at all, it’s comparable to a 3050ti. I see zero point in buying anything called a ‘workstation’ card unless it’s the absolute king of the hill, paying twice the cost of the best GeForce money can buy for 5% better performance makes at least some sense for some people.
I totally agree with David and Jim.
Usually pre-made pc/workstation have generic low tier components (motherboard, power supply, ram, ssd).
In that model you know in detail only the CPU (which is not overclock-able) and the GPU. The rest are a generic “32GB ram”, a generic “1024GB ssd” … unknown motherboard and psu.
Scary, imho.
But it’s not the first time seeing someone buying a pre-made workstation.
Why they do so? Because they care for the warranty part.
Is this your case, Federico?
Let’s imagine your GPU fail.
If it’s a custom assembled pc, you send the GPU out in warranty for replacement/repair … you’ll have to wait and in the meantime your workstation will not work unless you have another GPU.
If it’s the pre-made workstation, you’ll have to send the whole workstation! (maybe you can remove the SSD/drive?) … and then wait for it to return back. Maybe this second option is faster. Maybe not.
Do you trust the seller? Do you trust the manufactured?
I personally prefer to assemble my own pc and have control over its component separately.
Can you or your colleagues handle some do-it-yourself ?
If so, a custom build will be more powerful and cheaper.
