I have at the bottom left of R8WIP Legacy OpenGL display on a black background.
It appeared and now I can’t get rid of it. Any ideas why it has appeared?
Also when printing a drawing it is displayed all over the print as if it is a watermark.
That’s not possible at this time.
We are frequently changing which mode is active when Rhino is launched and we need to be able to keep track of which pipeline is being used. If you need to create drawings from screenshots, you’ll have to use Rhino 7 for the time being until this stabilizes.
Just type TestMetal again and you’ll be back to legacy OpenGL.
In the WIP while this part of Rhino is being worked on the mention of it in the viewport will stay until it is deemed good enough to disable the message.
