If I draw a leader, then do any operation which calls up an OSnap, lets say a move, if I hover the cursor anywhere in the bounding box of the leader, I will be given an End snap with a symbol. Any chance that can get cleaned up?
Thanks,
Sam
Thanks,
Sam
Hi Sam - here it’s not right but not as you describe either - if I have End on, End shows as expected on the leader vertices etc. If I have Point on, it gets the same locations - but if I have both on, I see the snap happen but there is no tooltip at all. So far I do not see the no-no…
https://mcneel.myjetbrains.com/youtrack/issue/RH-44631
for now…
Hmm, can you give it a shot on a leader with no text? Looking at it again, those seem to be more of the trouble makers.
Sam
OK- got that - with a blank leader, and End I see the no-no. Thanks.
