Leader distance between arrow and text
¿Is possible edit distance betwen arrow and text in a Leader… in Grasshopper.?
I guess you can type spaces before the text, if that’s what you mean?
otherwise this option (consider that the GH preview might be different from the baked one)
The GH preview should be the same as the baked one. If that’s not the case, please let us know.
Great, thank you very much.
With that it worked fine, when changing it in “options”.
However, I had already tried with “text gap” from grasshopper and the change did not work.
Can you post the Grasshopper and Rhino file you were using where the text gap setting didn’t work?
