What would cause my layouts panel to be blank - even though I have a whole lot of them!
In the past, I had to click on a layout and move it in order to get the panel to populate.
Now it shows blank but not on all my models.
Hi @CCBB
Pls run _SystemInfo in Rhino and post back the results.
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Commercial, build 2024-12-03
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 24Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GT 730 (NVidia) Memory: 2GB, Driver date: 9-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.12
> Accelerated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-13-2021
Driver Version: 30.0.14.7212
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 7\Plug-ins\RhinoCAM 2022 for R7\RhinoArt1FileExporter For Rhino7.0.rhp “RhinoArt1FileExporter”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
Hi Clint -
Does that mean that (a) you’ve always had issues with showing content in the Layouts
panel, and (b) the workaround of moving a layout no longer works?
I take it you have updated Windows since 2021. Window updates sometimes mess up display drivers and that might be the cause of the workaround not working anymore.
I would open the Rhino Notifications
panel and follow the links to a NVIDIA site where you can find up-to-date drivers for your hardware. Install those using the “Clean Install” option.
Also for Rhino 7 we recommend 4 GB of VRAM per monitor that is used, so you are rather underpowered here. Does disconnecting one of the monitors make a difference?
Correct to a) and b) - the workaround was simply that once I clicked on the layout on my main screen and move it with the pan button, the layouts list would only then populate the layouts panel on my left screen.
Windows is up to date. Graphics is not up to date but I cannot get it the Geforce driver to download and do its thing…working on that.
I am holding out until the office move for the new computer…thx for that point about the VRAM.
UPDATE: driver is now up to date, restarted and problem persists.
I also have problems getting my panels to stick when reorganizing them on my left-hand screen. I thought if I did that on a file, saved the file and closed Rhino that all other files would open with the new panel config.
We seem to be working now…weird but OK!
I stand corrected - it is an intermittent problem for sure. The same model works one day the next day the layouts panel will not populate. Any thoughts?
