Layout tabs & PDF wish
@stevebaer 's work on native PDF export and eventual printing jostled a wish I’ve had for a bit but never articulated, and that would be a more robust layout tab or layout properties that the user would be able to specify the default PDF file name for that sheet. My names for my layout tabs are short and succinct, as when you start getting up there in page count in a drawing package, you want to make as many fit as possible. The problem is on printing, you want the PDF file name to be consistent for each sheet (minus such things as date and revision letter). If would be great if for each layout sheet, you could right click on the tab, or perhaps set in properties for the layout the default PDF file name, with the ability to use text fields as well.
Thanks,
Sam
Hi Sam - thanks
https://mcneel.myjetbrains.com/youtrack/issue/RH-38062
