What is the difference between the window1 and window2 in the below photo, how to make window1 to show the same render image as window2 then. Because we plot the window1 to PDF, however, it looks we should plot window2 to pdf, how to acheive it then, Thanks a lot!
Hi Robin -
Window1 is a viewport with a certain display mode, most likely the Rendered
display mode.
Window2 is the window that appears when you use the Render
command.
If you put window1 into the Raytraced
display mode, you should get the same image as what you get when you render.
HTH,
nice, that is right what we are looking for, Thanks Wim!
3 posts were split to a new topic: Stuck in Raytraced
