Layout objects visible in model space when file is attached through worksession
Layout objects visible in model space when file is attached through worksession.
The problem appeared in the latest update (6.22.20028.13281, 28.01.2020)
The issue appears both it files created in previus builds, and in fresh drawings.
Please fix this as soon as possible, it makes Rhino not functional.
Thank you in advance!
Hello - this should be fixed - https://mcneel.myjetbrains.com/youtrack/issue/RH-56807
