Layout names not consistent in Rhino
Hello. When I rename layout using “Layouts” tab, it doesn’t appear to change the actual layout name in the bottom tabs. It actually changes back to the original name (before the change) after some time. Is this a bug or am I missing something important?
Its not honoring the case change. I can repeat and will get a youtrack going. Thanks for reporting RH-80833
