A strange behavior is happening when we made layout with locked detail view on it.
Here’s a video to show what’s going wrong (sorry for the poor video quality but all the recorder that i tried doesn’t worked as expected…).
This display bug stay even if i save the file or change of PC until i fix it.
It happens on VA object but if my memory is right, i have seen this before without VA installed.
A fix is to unlock the view and move or zoom on it. Obviously it’s not viable to do this on every layout of every project.
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Laptop GPU (NVidia) Memory: 4GB, Driver date: 3-17-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.15
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2022
Driver Version: 30.0.15.1215
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\f.bessiere\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\eleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
And more details on what i’m tring to show on the video.
1- First there is a detail view of “TOP R+1” on the layout named “Plan d’étage R+1” with doors not showing
2- But in the rhino viewport the view “TOP R+1” is showing these doors
3- If i change the render mode (VA or Rhino style) nothing happens, even in wireframe mode the doors aren’t displayed.
4- The only way I’ve founded to show these doors again is to unlock the details view, move or zoom in the view and then relock the view. (If I change the scale in the view properties panel, it does nothing, i have to do this with the mouse)
Thanks for those details. Would you be able to upload that file on Rhino Accounts with reference to this thread in the “Comments” field on that page?
We have been looking at this issue and the problem is that the view you are using is not completely vertical, so that 2D representation is not activated by VisualARQ. If you set it to Top view you should make it work properly.
I’m not the drawer here but maybe it’s a wrong manipulation when moving/zooming in the view. But I’d rather think it’s a bug as when i do the trick shown in video, of moving a little bit the view with the RMB, the camera goes back vertical automaticaly. If it was in perspective, let’s say that by mistake the view was moved using ctrl+shift+right mouse button. Then, it turned in perspective, but in that case the RMB doesn’t move the view anymore and tilt it. Do you see what I meen ?
I see what you mean. We have made VisualARQ to use the document tolerance by comparing the angle for the view direction, this way you will not have this problem if the view is not completely aligned. This has been implemented in the next VisualARQ release (2.13).
