Hello, I am new to Layout Pages. I know that you can set specific Layer Visibilities for Details with “Model On”. However if I change the overall Layer Visibility, it will override the “Model On” Visibility and turn it off aswell.
Is there a way around it, because otherwise it seems like when I am working I have to go back to the Detail and select Visibilities all over again.
What you’re running into is a mix-up between two different visibility controls that Rhino 8 keeps separate. The good news is that model-space and layout/detail visibility are now fully independent, so you shouldn’t have to re-set your details every time you work in the model.
There are three levels of layer visibility:
Global On/Off — the master switch. This hides or shows the layer everywhere at once — model space and every layout and detail. This is the one you’re currently toggling while working, which is why it wipes out your detail settings. Reserve it for construction/reference layers you never want to see or print anywhere.
Model On/Off — affects model viewports only. This is the one you want while modeling. Turning a layer off here does not touch your layout or detail visibility. When you come back to model space, your Model On/Off states are remembered.
Layout On/Off and Detail On/Off — per layout page / per active detail. Set them once and they’re preserved with the file.
So the fix is: while you’re working in the model, use Model Off (not the global On/Off bulb) to hide things in model views. Your details keep their own visibility.
A few pointers:
To reach the per-model and per-detail toggles, right-click the light-bulb icon in the Layers panel — you’ll see the extra options there. With a detail active (double-click into it), right-clicking the Detail On bulb also lets you turn a layer on/off in all details on the current sheet, or in all details across all layouts.
There’s a “Layer off in new detail” column in the Layers panel (the New Detail On/Off state). Enable it and any newly created detail will start with that layer already turned off — so finished layers stop showing up uninvited in new details as you keep working. Very handy once your model has a lot of layers.
We wrote up the full picture with screenshots here, which should make it click: Layouts are Safe in Rhino 8.
To answer the follow-up question — the classic Global On/Off still has a purpose: it’s the single master override that guarantees a layer is hidden (or shown) everywhere, regardless of the per-model/per-layout/per-detail settings.
