Please look at the attached snippets of Rhino 6 latest release.
My Layout contains one rendered viewport of the front elevation of the scene
When I reposition the ‘live’ viewport then double click out of it onto the layout page I get this ‘ghosted’ double image - a combination of the previous rendered view and the repositioned one. It is a ghost of the previous position as I’ve experimented with this.
It doesn’t show in the live viewport but only on the page layout.
It also appears on all print formats.
Open Rhino
Load the document
Click on Page 1 tab - which is a layout template with 1 viewport - in this instance, the front view
Make the viewport ‘live’ by left button double clicking in it
Right button click and hold then drag the view to a different position
It’s this last process that seems to cause the problem - when I then left button double click to ‘kill’ the viewport and return it back to it’s ‘page layout’ state this reveals the ‘ghost image’ or original position of the view before the right button hold and drag.
I hope this makes sense and thank you for any advice.
Hi David - thanks, that is what I understood was likely it, but it does not happen here so far. If possible please send (as small/simple as possible) an example file that shows this to tech@mcneel.com to my attention - please also include a link back to this topic in your comments - I have a feeling it will be hard to reproduce what you have so getting it direct will be helpful, I hope.
Please also run SystemInfo in Rhino and copy/paste the results here.
Thanks Pascal,
I’ve sent in the .3dm file by email and here is the systeminfo stuff.
Rhino 6 SR33 2020-12-8 (Rhino 6, 6.33.20343.16431, Git hash:master @ d492bef53a3f6a576db4d197feaaa7ddf0c7a653)
License type: Educational, build 2020-12-08
License details: Cloud Zoo. In use by: David Cooke ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-UMVVNLO
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1080 Ti (NVidia) Memory: 11GB, Driver date: 12-11-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 460.89
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-11-2020
Driver Version: 27.21.14.6089
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.33.20343.16431
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.33.20343.16431
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.33.20343.16431
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.33.20343.16431
