Hi!
I can’t see my detail views in layout behind hatch I made to the layout. I tried drafting send to back. And detail views Bring to front. But no good result… Is it possible? I think I have to find some other more difficult solution…
Dear @Wagner you might want to post a file or screenshot - to show what is not working exactly - or even fake the desired result in photoshop…
you can _explode a standard hatch (pattern) to get lines / curves (gradient will get lost) …
put it on a single layer. Then maybe:
BringForward
BringToFront
SendToBack
SendBackward
those commands allow to change the drawing-Order …
kind regards -tom
Hi Tom!
Thank you for your help. Picture is good idea, just busy to concentrate…
I hope you get what I mean…
Used these but did not work…
And we are in layout at the moment.
I don’t want to make hatch with holes, because then I should have 30 holes and I have to fix the sizes of details… Then have to delete hatch and make it again and draw borders etc… I just want background behind details, without I have to make new detail size of the filled area I want and then draw and fill area to the top view…
I like Rhino because there is options/different ways to do, but this is the easiest way I want to do it… It should not be so difficult. Just send hatch back and see details…
