Hi
Here’s the problem… when creating dimensions in a layout, and ‘faking’ the dimension value “tightenfactor0” is inserted. See screenshot.
I have just done a full reinstall, and it’s still happening.
Has anyone seen this issue?
Rob
Hi Rob -
I’m not seeing that here. Can you post a simple file that behaves like that on your system?
I’m not able to replicate it in a clean file. It seems that it comes from the geometry in the file. I’ll repost an update when the problem comes up again.
I am having the same problem. I used to be able to fix stuff like that by closing rhino and opening it again, but now it stays even after the shutdown.
Hi Gabrielle -
I am reviving this again. I wasn’t able to replicate it before. But I think I have finally figured out what causes the bug. I have uploaded a file with the bug. It is demonstrated in the Layout page. It has something to do with selecting dimensions all with overridden text inputs and trying to format them [Bold, italic etc].
tightenfactor0_BUG.3dm (2.7 MB)
Hi Gabrielle -
Thanks for the file and additional details. I was able to reproduce that here and put the issue on the list of a developer for a closer look - RH-68249.
Great! Thank you. Do you think it will be ironed out in the next update?
Hi Gabrielle -
I really don’t know. This thread will be notified when the bug is fixed.
Hi, I still have this problem sometimes. Has there been a fix? or a work around discovered? I need to override the “<>” in my drawings sometimes.
Hello, have the same issue with dimensions drawn in model space. Any workarounds or how do i fix so i dont recieve the bug anymore? Even newlydrawn dimensions has the bug persisting.
Rhino 8 on Macbook Pro 2019, MacOS 15.3.1 (24D70)
Thanks for any help
Hej Josef -
The workaround is to remove the style override on the annotation.
