Layout and PDF automatically (C++)
I would like to automate the export of some 2D drawings…create the layout (frame, stamp, etc…) and export it as PDF. I haven’t done any of those things before - haven’t programmed anything related to the layout or exported drawings as PDFs…
So, I would like some general advice for starters. What classes to use? For Layout? For PDF export (print)? Of course some code examples would be perfect.
Thanks a lot!
Milos
Hi Milos,
A layout (or page) view is represented by a CRhinoPageView object, which is derived from CRhinoView.
To retrieve all of the page views in a document, you can do something like this:
ON_SimpleArray<CRhinoView*> view_list;
context.m_doc.GetViewList(view_list, false, true);
To determine whether or not a view is really a page view, you can do this:
CRhinoView* view = ...;
bool bPageView = (view->RhinoViewType() == CRhinoView::page_view_type);
To cast a CRhinoView to a CRhinoPageView, you can do this:
if (view->IsKindOf(RUNTIME_CLASS(CRhinoPageView)))
  CRhinoPageView* page_view = static_cast<CRhinoPageView*>(view);
  if (page_view)
    TODO...
A page view can contain one or more detail view, which represented by CRhinoDetailViewObject.
To get all of the details from a page you, you can do this:
ON_SimpleArray<CRhinoDetailViewObject*> detail_list;
page_view->GetDetailViewObjects(detail_list);
This should make you dangerous. :wink:
– Dale
Hi Dale,
thanks! I will look into it this week. As I understood with this class I can set all the parameters I need (paper size, frame, etc…). And how do I actually automate the export? Printing to PDF? What classes/functions are used for that?
Greetings,
Milos
P.S. Additionally to printing automatically to PDF (howdo I set printer properties of the layout? ), can I automatically set all the variables that open in a print dialog( View and Output Scale, Margins and Positions, Linetypes and Line Widths, …)?
Thanks!
