Hi all,
What is the most elegant way to find the max depth within a LayerTable?
This is what I wrote so far:
Was wondering if I missed any RhinoCommon method that would be more efficient…
Best
Paul
Hi all,
Best
Paul
At least you could build your max depth inside the loop.
int maxDepth = 0;
foreach (var layer in layers)
maxDepth = Math.Max(maxDepth, LayerDepth(layer));
return maxDepth;
private int LayerDepth(Layer layer)
string path = layer.FullPath;
string reduced = path.Replace("::", string.Empty");
return (path.Length - reduced.Length) / 2;
Nice one, thanks! Even though I am surprised that RhinoCommon does not contain a function to calculate a Layer’s depth.
Also, if I am not wrong, this line of code…
…should be like:
return (path.Length - reduced.Length) / 2 + 1
That depends on whether a top-level layer is considered to be at depth=0 or depth=1. Either is fine, there’s no official definition of depth.
yes, fair enough!
