Layers panel crashing
Hi on the 06-09 WIP I am getting crashing on opening some (but not all)files, that seems to be caused by something in the Layer panel. Hiding(tabbing away from)the layer panel lets the files open, but they crash on switching to the layer panel.
Reports have been sent.
This seems weirdly to have begun days after starting to use that WIP, so like it was a Windows update? But even that was days ago also.
Not sure if this is related but I’ve been having issues for a while…
WIP layer panel freezing - Serengeti (Rhino WIP) - McNeel Forum
@JimCarruthers are there some steps I can try to repeat the issue (I see the tab switching you mention but haven’t tried to repo yet.) is there a file that triggers it more than others that you could share with me?
The files I attached with the crash reports crash on open if the layers tab is visible…can’t find a pattern to which ones crash yet, like date range or certain kinds of objects…
Ok thanks. We are looking for your crash reports but not coming up with any yet?
I’ll have to send one privately then…
Thank you! That would be very helpful!
Hi Jim -
This one should be fixed in the current public WIP. Could you update and check?
→ RH-96238 KERNELBASE!RaiseException –
So far so good.
RH-96238 is fixed in Rhino 8 Service Release 34
