Layers in layout windows, on off
Hi, where can i find the command so that i can turn on and off the layers in layout windows at the same way as in model mode?
You can turn these on and off per detail in the layer manager - just make sure to scroll all the way to the right to find the right light bulb.
Ok,Thanks:slight_smile:
You can also configure the column display to only show the per-detail settings.
Sometimes less is more…
