The layers commands in Python seem to have some problems in the latest Mac Rhino5 WIP as of 6/22/17.
ExpandLayer does not work, either for expanding or contracting layers.
I have a sort routine for sub-layers that creates a new working layer (at the bottom of the layers), changes one of the existing layers to be a sub layer of the new layer, then changes the layer hierarchy back down. In Windows Rhino 5, the result is that the layer needing to move becomes a sub-layer of the new layer, then drops back to the original hierarchy level at the end of the layer list. In Mac, the layer is placed in the sub-layer of the new layer (end of layers position) but the layer does not get expanded as in Windows. The expand function will not show the sub-layer and when the new sub-layer is placed back to its normal level, it gets put back to its previous location in the list, not at the end where I want it.
A better solution would be to have a MoveLayer or SortLayer function built-in, but this method should work like the Windows Rhino does.
Here is the SubLayer sort routine:
from scriptcontext import doc
from System import Guid
import re # for sort
# sort sublayers
def test_sort():
SortSubLayers('BoltGen')
# SubLayer Sort Routine
def SortSubLayers(ParentLayer):
ParentLayerID=0
sorted_layer_names = []
for layer in doc.Layers:
if layer.Name == ParentLayer:
if not layer.IsDeleted:
ParentLayerID = layer.Id
break
if ParentLayerID == 0: return False
# Parent layer ID found
if layer.ParentLayerId == ParentLayerID:
sorted_layer_names.append (layer.FullPath)
# We have list. Set up working layer.
tmp_layer_name = rs.AddLayer(Guid.NewGuid().ToString(),parent=ParentLayer)
tmp = doc.Layers[doc.Layers.FindByFullPath(tmp_layer_name, False)]
rs.EnableRedraw(True) # must be active to work, but the parent layer may be contracted.
# sort for alpha numeric
sorted_layer_names = sort_alphanum(sorted_layer_names)
for Full_Path in reversed(sorted_layer_names):
Wk_Layer = doc.Layers[doc.Layers.FindByFullPath(Full_Path, False)]
parLayer = Wk_Layer.ParentLayerId # save parent
Wk_Layer.ParentLayerId = tmp.Id # set temp as parent layer for Full_Path to shift index location
Wk_Layer.CommitChanges() # force completion
Wk_Layer.ParentLayerId = parLayer #position work layer layer back to parent layer (Hopefully at end of layers list)
doc.Layers.Delete(tmp.LayerIndex, True) # remove working layer
#rs.MessageBox('Finished test') # test list
return True
def sort_alphanum(LayerList):
convert = lambda text: float(text) if text.isdigit() else text
alphanum = lambda key: [ convert(c) for c in re.split('([-+]?[0-99]*\.?[0-99]*)', key) ]
LayerList.sort( key=alphanum )
return LayerList
if( __name__ == "__main__" ):
test_sort()
