Layer problem in V8
I have a customer file that reveals 2 layer control problems.
Unfortunately, it’s a confidential file.
Uploaded with link to this post.
1
The “Select object layer” function doesn’t work with a certain object.
Works in V7 and V9, not in V8.
2
This is a severe one:
There is one layer, it’s visibility is switched off (grey bulb).
When I click the bulb to make the layer visible, nothing shows in the viewport.
On the layer there are several existing objects.
_Show doesn’t help, there are no hidden objects the commandline says.
The only thing that helps to make the objects visible is _OneLayerOn with this layer.
Doesn’t work in V8 and V9, in V7 no problem.
I can see the file has at least one layer with it’s “Model On” property turned off.
– Dale
Oh!
Bad I didn’t see that.
Good it’s not a Rhino error.
I wonder what the customer did to the file…?
Ok, thank you for the quick solution Dale.
Could the models be there just it’s not in the center?
Can’t recall it at the top of my head but see if something like “zoom to object” icon exists.
I know that icon, but that is not related to the problem :wink:
Didnt see Dale had the solution my bad :joy:
