Layer Print Color
Hello
Every time I change Layer Color, Layer Print Color changes.
I would like to organize layers to be always printed on black, no matter what the Layer Color is.
Is that possible to breake this dependence?
Regards
Hi @KaTa, by default, if no print color is set for a layer it uses the layer color.
You could set black and white whenever you print from the print options dialog:
grafik
or create a template with your favourite layers using dedicated print colors.
_
c.
You can also put the following macro on a toolbar button or alias:
! _-Layer _PrintColor * 0,0,0 _Enter
which will set all layer print colors to black.
–Mitch
Thanks.
But what if I want to have many Layout Print Colors, not only Black and White?
I work on very complex models with a lot of elements, and I often change Layer Colors to improve visibility in Shade Mode. But I don’t want it to effect Layer Print Colors. Unlinking these two values would be useful.
