Layer panel - one more wish
Hello!
When a sublayer is the last item in the layer list, dragging some layer to the bottom of the list leaves no choice but making it another sub-layer.
Expected behavior: make it sublayer, or, when dragging it a little bit further down, a ‘top level’ layer.
E.g. Affinity apps work that way:
Thank you!
hi @Eugen thanks for reporting, seems a Windows only issue
RH-76979 Dragging a layer below a layer that has child layers is not possible
(note that currently it is possible to drag it below, if you collapse the parent)
